1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: scanRecord for 3.14
To: [email protected]
Date: Fri, 05 Dec 2003 15:01:32 -0600
The next 3.14 release will support put callbacks for database channel access links. This is being done so that synapps can remove it's dependence on recDynLink.
3.13 and early versions of 3.14 has support for scanRecord. This was removed from 3.14 because it required recDynLink. Now that put callback links will be supported the scanRecord could be easily modified so that it no longer requires recDynLink.
The question I have is does anyone use scanRecord?
Synapps provides sscanRecord which provides more functionality than scanRecord so is scanRecord still needed?
Marty Kraimer
Re: scanRecord for 3.14 Ernest L. Williams Jr.
Prev: Re: Novice EPICS questions re yet another port Eric Norum
Next: RE: scanRecord for 3.14 Redman, Russell O.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CA FLNK Luedeke Andreas
Next: Re: scanRecord for 3.14 Ernest L. Williams Jr.
