1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: stringIn record monitors
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Wed, 02 Apr 2003 15:18:55 -0500
>>> On 4/2/2003 at 13:13:41 CST, Tim Mooney wrote:
  >> Does anyone see any reason not to do this ?
  > It's not hard to imagine this change to the stringout record causing a
  > problem with save_restore, but if you were to follow the model in the
  > ai record (i.e., have MDEL and ADEL fields, compared with the result of
  > strncmp(old,new)), then those who rely on the current behavior could
  > probably get what they need by specifying the mask DBE_LOG in their
  > call to ca_add_event().
To me it makes little sense for MDEL and ADEL to have "values", especially
since string comparisons should be "locale dependent".
My thought was for them (or new fields - possibly less confusing?) to be
binary flags that specify whether to force monitor() to post .VAL on every
record process.
These fields would default to 0="don't force", so existing databases would
produce the existing behavior from the modified records.
Or am I missing something else ?
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: stringIn record monitors Tim Mooney
Prev: Re: stringIn record monitors Tim Mooney
Next: Re: stringIn record monitors Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
