1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: stringIn record monitors
To: Brian McAllister <[email protected]>
Cc: [email protected]
Date: Wed, 02 Apr 2003 13:13:41 -0600
re...,
Brian McAllister wrote:
> >>> On 4/1/2003 at 16:32:58 -1000, Bill Cruise wrote:
>   > Has someone developed a "standard" string record that does provide a
>   > monitor for every input?
> This behavior is particularly desirable for soft records.  It would be
> trivial to add a field to stringin/stringout to specify that a monitor
> should be posted every time the record is processed.
> It would also be completely backward compatible with existing databases.
> Does anyone see any reason not to do this ?
It's not hard to imagine this change to the stringout record causing a
problem with save_restore, but if you were to follow the model in the ai
record (i.e., have MDEL and ADEL fields, compared with the result of
strncmp(old,new)), then those who rely on the current behavior could
probably get what they need by specifying the mask DBE_LOG in their call
to ca_add_event().
Tim Mooney ([email protected]; 630-252-5417)
Advanced Photon Source
APS Operations Division
Beamline Controls & Data Acquisition Group
Re: stringIn record monitors Brian McAllister
Prev: Re: stringIn record monitors Brian McAllister
Next: Re: stringIn record monitors Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
