I am experimenting with EPICS base R3.14.1. running it on a standard RedHat7.3 machine. I have written device support for a few NI DAQ cards, which is going very well. Great. If you're willing to make this code available to other sites when it's finished, please submit entries for those cards to the EPICS Hardware Support list. </commercial> The scan period seems to be consistently extended by an 100th of a second, when using device support. I first noticed this when I toggled a binary out at 10Hz to generate a square wave. I saw the effect very clearly on the oscilloscope. Here is the ca-monitor with empty device support Yes, and I spent some time looking at it many months ago, although I can't remember the exact details now. IIRC it occurs because the linux kernel uses a 100Hz clock tick, and doesn't do timer arithmetic to an accuracy greater than that tick, so depending on how long your scan task takes to execute, the system call that implements nanosleep() frequently rounds up twice, adding an extra 0.01 seconds to the delay. This is definitely not due to an EPICS bug (I checked that at the time), and I don't think there's any easy way to get around it other than possibly explore the high resolution timer kernel patches that are supposed to exist - I've never tried them though. - Andrew -- Tongue-twister: Say "Peggy Babcock" 10 times without stumbling...
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
