1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: device support for R3.14.1 Linux IOC
To: [email protected]
Date: Wed, 5 Feb 2003 16:26:03 -0500 (EST)
Hello,
	I am  experimenting with EPICS base R3.14.1. running it on a
standard RedHat7.3 machine. I have written device support for a few NI DAQ
cards, which is going very well. In doing so, I noticed something
strange.  The scan period seems to be consistently extended by an 100th
of a second, when using device support.  I first noticed this when
I toggled a binary out at 10Hz to generate a square wave.  I saw the
effect very clearly on the oscilloscope.
	I then had a look at the time-stamps and saw the same thing.  To
see if this was due to device support, I built an example with device
support that did nothing.
static long Inuit_bo();
static long write_bo();
struct {
	long		number;
	DEVSUPFUN	report;
	DEVSUPFUN	init;
	DEVSUPFUN	init_bo;
	DEVSUPFUN	get_ioint_info;
	DEVSUPFUN	write_bo;
}devBoDIO96={	5,NULL,NULL,init_bo,NULL,write_bo,};
static long init_bo(pbo)
    struct boRecord	*pbo;
 return(0);
static long write_bo(pbo)
    return(0);
like so.
The scan rate was set to .1 and the same problem occurred.
Here is the ca-monitor with empty device support
 DML:Bo0                        02/05/03 16:06:27.070044
 DML:Bo0                        02/05/03 16:06:27.280062
 DML:Bo0                        02/05/03 16:06:27.490039
 DML:Bo0                        02/05/03 16:06:27.700034
 DML:Bo0                        02/05/03 16:06:27.910037
 DML:Bo0                        02/05/03 16:06:28.120074
 DML:Bo0                        02/05/03 16:06:28.330045
 DML:Bo0                        02/05/03 16:06:28.540051
 DML:Bo0                        02/05/03 16:06:28.750047
 DML:Bo0                        02/05/03 16:06:28.960049
Using soft records, there is no such problem.
Has anyone else noticed this?
any help would be greatly appreciated
best regards.
Dylan Maher-Loughnan
MIT-Bates Linear Accelerator Center
Re: device support for R3.14.1 Linux IOC Andrew Johnson
Prev: EPICS base release 3.13.8 Marty Kraimer
Next: Re: device support for R3.14.1 Linux IOC Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
