1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: alarm handler
To: john sinclair <[email protected]>
Cc: Marty Kraimer <[email protected]>, tech talk <[email protected]>
Date: Wed, 14 Aug 2002 17:11:51 +0200
>>>>> "John" == john sinclair <[email protected]> writes:
  > I see in alh the following code:
  >   status = ca_put(DBR_PUT_ACKS, chid, psevr);
  > but alh does not seem to affect the ACKS field of a pv
  > which explains why two instances of alh are not necessarily
  > in sync with respect to the acknowledged state of a pv.
  > Is this the result of improper configuration on my part?
Keep in mind that both alh instances have to run in "global" mode to
access the records' ACKS fields, otherwise acknowledgement is done only
local, i.e. within the alh instance.
You can see the status of the alh in the lower left area of the Main
Window ("Execution Status").
"Global" is the mode intended for control room instances of alh that
should run sychronized, "Local" is the mode for running alh on a
personal office workstation, where you want to acknowledge the alarm
just for yourself.
Ralph
Re: alarm handler john sinclair
Prev: Re: alarm handler john sinclair
Next: RE: Large arrays over CA - attempt #2 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Passing large arrays over channel access with R3.14b2 S. Joshua Stein
