In the simple drvNode framing routines I alluded to earlier
we allowed a set of multiple terminators. On a character by
character basis the index into each terminator was incremented until
either a mismatch occurred or a complete terminator was found.
While in our application we defined the terminators at the vxWorks command
line, modifying the drvAscii <readCmt> construct would be
straightforward.
drvNode usage is:
* A delimiter definition includes:
* n - index into delimiter array [0..NDELIMITERS-1]
* len - length of delimiter in characters. (0 = delimiter not defined)
* delim - delimiter string
* mask - bit mask indicating which positions are wild carded.
* Examples:
* drvNodeSetDelim(COMMON, 2, 2, "\015\012", 0x00)
* delimiter #2 = CRLF
* drvNodeSetDelim(MOUSE, 0, 3, " ", 0x07)
* delimiter #0 = any sequence of three characters (useful
* for mouse pointing devices).
By adding two optional syntax elements to the drvAscii <readCmt>
links this could be emulated, i.e.
o add an optional delimiter number (default=0)
o allow a %k construct within the terminator string
(default = not used).
So the examples above could be written as:
field(OUT,"@COMMON <readCmt 2 %s>")
field(VAL,"\015\012")
and
field(OUT,"@MOUSE <readCmt %s>")
field(VAL,"%3k").
Note that drvNode returns the terminator string.
- Peregrine
Peregrine M. McGehee [email protected] (505) 667-3273
Sloan Digital Sky Survey / Spallation Neutron Source
MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
- Re: CA "connection lost" messages Brian McAllister
- Help about epics Monitor using CORBA guobao shen
- Re: drvAscii - termintor strategy Eric Williams
Re: drvAscii - termintor strategy Allan Honey
<2002>
strange behaviour of dbLoadtemplate Werner Portmann
<2002>
