(if somebody prefers to make the experience rather than reading do first dbLoadtemplate test1.subs second dbLoadtemplate test2.subs the short files are at the end of this longer mail) recentely I found a very strange behaviour of dbLoadtemplate. For a special device the result of dbLoadtemplate had to look like: record(mbbo,"test:CON-FUNC") { field(ZSTR,""CURR:DC"") ..... It is important that there are 2 qoutation marks just one after the other at the beginning and at the end. I found no other solution than to have a template file with field(ZRST,"$(qm)CURR:DC$(qm)") and in the substitution file I put qm = '\"' This worked perfectely, the whole substituion file test1.subs is at the end of this mail: I got the request to add an other record, an easy job, I thought, but .... test2.subs is at the end of the mail, too and the result of dbLoadtemplate: in words: it did not substitute qm with " but with the rest of the file! (I put ">" to show that this is the output) >..... > > field(ZRST, ""'} > >{ NAME = X09LA-KCUR2 > GPNR = 11 > qm = '"CURR:DC"'}> > >{ NAME = X09LA-KCUR2 > GPNR = 11 > qm = '"") > field(ONVL, "1") >.... After playing around I found no other solution than to have 2 dbLoadtemplates, each one loding one record. Thanks for any hints Werner ************** files ************ test1.subs >file test.template { >{ NAME = X09LA-KCUR > ADDR = L38940 > GPNR = 10 > qm = '\"'} >} test2.subs >file test.template { >{ NAME = X09LA-KCUR > GPNR = 10 > qm = '\"'} > >{ NAME = X09LA-KCUR2 > GPNR = 11 > qm = '\"'} >} test.template >record(mbbo,"$(NAME):CON-FUNC") { > field(ZRVL,"0") > field(ZRST,"$(qm)CURR:DC$(qm)") > field(ONVL,"1") > field(ONST,"$(qm)VOLT:DC$(qm)") >} -- Dr. Werner Portmann, SLS computing and controls Paul Scherrer Institut, CH-5232 Villigen PSI tel + 41- 56 3104061 fax + 41 - 56 310 4413 e-mail: [email protected] http://people.web.psi.ch/portmann/
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
