1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA client library and Connection handler
To: <[email protected]>
Cc: <[email protected]>
Date: Wed, 06 Feb 2002 10:37:49 -0500
>>> On 2/4/2002 at 18:44:33 MST, Jeff Hill wrote:
  > Perhaps there is a difference between your compiler switches and ours.
  > Here is a quick summary of what is used to build EPICS R3.14. This
  > should be similar EPICS R3.13.
  > gcc -D_REENTRANT -ansi -O3 -mpentium -fPIC
  > I am guessing that your lack of either -fPIC or -D_REENTRANT might be
  > the cause.
It turns out that the problem was due to a Linux version mismatch.  Adam
was building his program on Redhat 7 (libc 6), but linking against EPICS
libraries built on Redhat 4.2 (libc 5) (we have to maintain both for the
moment).
With the correct version of the libraries the program works as expected.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
RE: CA client library and Connection handler Jeff Hill
Prev: Re: logging of changes to PVs Ralph . Lange
Next: RE: "Unexpected UDP failure WIN32 Socket Library Error 10054" Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: CA client library and Connection handler Jeff Hill
Next: 2'nd Iocsh with win32. Bad soft-record support? kuner
