Thank you Pete Jemian and Tim Mooney,
but unfortunately the problem is still the same, if I call dbLoadRecords
in the proper way. There is no record support:
C:\project\epics\base-3.14.beta1.Apps>example
epics> dbLoadDatabase "dbd/example.dbd"
epics> dbLoadRecords "db/dbExample1.db", "user=HORST"
Error Last token ")"
input line: record(ai, "HORST:aiExample")
in: file db/dbExample1.db line 1
db_parse returned -1
epics> dbAllocRecord(ai) record_size =0
filename="..\dbLexRoutines.c" line number=869
Record support not found new record instance error
epics> iocInit
### @(#)EPICS IOC CORE built on Jan 25 2002
### @(#)Version R3.14.0.beta.1 $R3-14-0-beta-1$ $2001/09/13
19:13:12$
Starting iocInit
iocInit record support for ai not found
iocInit record support for ao not found
Is it possible to do something wrong when building the base? I suppose
the linker uses only the functions the program refers to, but record
support functions are called by pointers and not by name, so it may be
they are NOT linked in the example.exe. May this happen?
Is there anybody in the epics-world who make this example run with a
Windows-PC?
Gruessle
Bernhard Kuner
----------------- [email protected] -----------------
- Re: 2'nd Iocsh with win32. Bad soft-record support? kuner
CA client library and Connection handler Adam Jon DeGrush
Epics 3.13.5 supporting Windows 2000 ? Goetz Pfeiffer
<2002>
Re: CA client library and Connection handler Brian McAllister
<2002>
