1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: porting record to 3.13.4 (part 2)
To: Andrew Johnson <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 24 Oct 2001 18:21:04 -0300
Hi Andrew,
Thanks for the hint, it fixed the problem. I now have yet another one
with the initialization of fields at startup. For instance, for the SIMM
and DBUG fields I have:
menu(ecsMotorSIMM) {
        choice(SIM_NONE,"NONE")
        choice(SIM_VSM,"VSM")
        choice(SIM_FAST,"FAST")
        choice(SIM_FULL,"FULL")
menu(ecsMotorDBUG) {
        choice(DBUG_NONE,"NONE")
        choice(DBUG_MIN,"MIN")
        choice(DBUG_FULL,"FULL")
        choice(DBUG_MAX,"MAX")
at the beginning of ecsMotorRecord.dbd. The fields are defined as
follows:
        field(SIMM,DBF_MENU) {
                prompt("Simulation Mode")
                asl(ASL1)
                pp(NO)
                interest(1)
                menu(ecsMotorSIMM)
                initial("0")
        field(DBUG,DBF_MENU) {
                prompt("Debug Mode")
                asl(ASL1)
                pp(NO)
                interest(1)
                menu(ecsMotorDBUG)
                initial("0")
Despite the "initial" statements, SIMM and DBUG have big (and invalid)
values after iocInit completes. Any ideas?
Thank you,
Pedro.
Andrew Johnson wrote:
> Pedro Gigoux wrote:
> > dbLoadRecords "./data/ecs.db"
> > filename="../dbStaticRun.c" line number=667
> > Missing SizeOffset Routine - No record support?
> > _ecsMotorRecordSizeOffset
> > 0xf4f008 (tShell): memPartFree: invalid block 0x734d in partition
> > 0xbd288.
> > 0xf4f008 (tShell): memPartFree: invalid block 0x14fbc in partition
> > 0xbd288.
> > 0xf4f008 (tShell): memPartFree: invalid block 0x7930 in partition
> > 0xbd288.
> > Cannot set field FLNK to ec:domeMotorFan.VAL  ((null))
> > Cannot set field DSTL to ec:domeC.IVAL .PP.NMS ((null))
> > Cannot set field MSGL to ec:domeC.IMSS .NPP.NMS ((null))
> > Cannot set field DBGL to ec:debugM ((null))
> > Cannot set field SIML to ec:simulateL ((null))
> > dbAllocRecord(ecsMotor) record_size =0
> > What's the function of this SizeOffset routine? I don't seem to find a
> > reference to it in the source code of other records.
> It gets generated automatically in the .h file that is created from your
> record.dbd file.  In the record support routine you have to define and
> then undefine the macro GEN_SIZE_OFFSET around the #include of that .h
> file, for example the following is the relevent part of the aiRecord.c
> file:
> #define GEN_SIZE_OFFSET
> #include "aiRecord.h"
> #undef  GEN_SIZE_OFFSET
> This causes the routine to be built into your record.o file.  The other
> errors may be related to not having that routine defined, I'm not sure.
> - Andrew
> Perfection is reached, not when there is no longer anything to add,
> but when there is no longer anything to take away.
> - Antoine de Saint-Exupery
Re: porting record to 3.13.4 (part 2) Marty Kraimer
porting record to 3.13.4 Pedro Gigoux
porting record to 3.13.4 (part 2) Pedro Gigoux
Re: porting record to 3.13.4 (part 2) Andrew Johnson
Prev: CapFast Windows version special Dr. Chong Lee
Next: Re: porting record to 3.13.4 (part 2) Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: porting record to 3.13.4 (part 2) Andrew Johnson
