1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: shared libraries build bug
To: [email protected]
Date: Thu, 27 Sep 2001 10:24:00 -0500
Update to shared libraries build bug:
The bug in the config/RULES.Host file of EPICS base did not stop
builds of shared libraries for base releases R3.13.3 and R3.13.4.
This bug shows up only in base releases R3.13.5 and R3.14.0.alpha2.
In these releases DLL_LIBS is defined in CONFIG.Host.UnixCommon. In
the earlier releases, DLL_LIBS and DLL_DEPLIBS were only defined for
WIN32 and Borland hosts.
For R3.14.0.alpha2 this bug will stop shared libraries builds only
when building a R3.13 extension or application with R3.14.0.alpha2
base.
The bug fix remains the same.
Bug fix: Remove the following lines from config/RULES.Host
         ifneq ($(words $(DLL_LIBS)), $(words $(DLL_DEPLIBS)))
         #  If invalid library names, don't make DLL file
         SHARED_LIBRARIES = NO
         endif
Janet
shared libraries build bug Janet Anderson
Prev: serial stuff on r3.14 Allan Honey
Next: mvme162PA-344SE and mvme162-532A Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: shared libraries build bug Janet Anderson
Next: 3.14 on Linux Ian A Smith
