1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: serial stuff on r3.14
To: [email protected]
Date: Mon, 24 Sep 2001 09:38:40 -1000 (HST)
Aloha
About 2 years ago I was debugging a problem that we suspected was in
drvAscii. I decided to debug this problem on UNIX so I could use the
UNIX compliation tools and debuggers. To this end I created 'glue'
code so as to be able to run drvSerial and drvAscii on UNIX (the intent
was to leave those drivers untouched, as much as possible). This all
worked fine.
The 'glue' code is mainly system call translations (semaphores,
spawns, ...). This code should be subsumed into the drivers.
Since that time I have successfully driven an instrument rotator, whose
motor controller has a serial interface,  using the 'glued' drvSerial and
drvAscii, along with an updated tnet driver.
In most cases, the EPICS databases using drvAscii and developed for Vxworks,
will run on the r3.14 UNIX platform by simply changing the port designations
(which should be a macro substitution), with the 'glue' drivers.
I will try and update the drivers to eliminate the 'glue' sometime soon.
cheers,
	A Honey
Prev: Re: 3.14 on Linux Andrew Johnson
Next: Re: shared libraries build bug Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: 3.14 on Linux Matthieu Bec
Next: mvme162PA-344SE and mvme162-532A Dale L. Brewe
