1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA throughputs
To: Lifang Zheng <[email protected]>
Date: Mon, 11 Dec 2000 08:33:17 -0600
Lifang Zheng wrote:
> Hi all,
> Does somebody know what is the unit of the following throughputs? bit?
> byte? or record?
> In the manual of "EPICS IOC Application Developer's
> Guide(R3.13.0beta12)" page 6, it says a 68040 IOC can process more than
> 6,000 records/s. If I am right, the unit of 10K/sec  monitors throughput
> can't be the record?
I am going to guess that the 10K/sec number is from a paper describing Channel
Access. If so it refers to a performance test that involves just Channel Acccess
and not record processing.
Note also that performance tests on a powerPC has shown a factor of 10
performance increase over a 25 MHz 68040. The test involved record processing
but with no CA clients attached so it does not measure CA performance.
Marty Kraimer
CA throughputs Lifang Zheng
Prev: Re: HP E2050A LanGpib gateway driver Benjamin Franksen
Next: Re: HP E2050A LanGpib gateway driver Eric Norum
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: CA throughputs Lifang Zheng
Next: C++ API backwards compatibility Jeff Hill
