1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: HP E2050A LanGpib gateway driver
To: [email protected]
Date: Mon, 11 Dec 2000 13:28:57 +0100
Andrew Johnson wrote:
> Mathew Rippa wrote:
> > Has anybody experienced problems with the LanGpib driver from Benjamin Franksen
> > (any version) returning the wrong ioc address? I have consulted Peter Mueller
> > (from Bessy) on this. It looks like a bug in the call to
> > "get_myaddress(&iocAddr)".
> > The driver returns only 128.171.0.0 when our actual address is 128.171.90.150
> > .. As a result it incorrectly thinks our gateway is 128.171.0.59,  which is
> > actually 128.171.90.59 .  Verbose details below...
> In section 2.4 of the lanGpib documentation, ie at
> http://www-csr.bessy.de/control/SoftDist/gpib/doc/lanGpib-8.html#HEADING8-0
> there is a paragraph labeled WARNING indicating that the driver does not
> use the IOC's _subnet_ mask but its _netmask_ to determine the box's IP
> address.  128.x.x.x is a Class B address, so your netmask is 255.255.0.0,
> although your local subnet mask may be 255.255.255.0 (which is irrelevent
> for this driver).  The link part of your GPIB hardware addresses need to
> have 90*256=23040 added to them.  This caught us at APS the first time
> too.
Yes. Thanks for pointing this out, Andrew. I am not so fast answering
GPIB questions these days, because my brain is so stuffed with other
things.
> There is a quick reference for IP address classes at
> http://foldoc.doc.ic.ac.uk/foldoc/foldoc.cgi?Internet+address
> Ben - I suggest you revise the wording of that paragraph, and maybe add an
> example as well to make it more obvious.  Something like:
> WARNING: The IP address of the gateway is determined by combining the
> value in the link field with the network part of the IOC's address, not
> the subnet part.  If the gateway's IP address is A.B.C.D and A is between
> 128 and 191, then you have a class B network, so your link address must be
> C*256+D.  If A is between 192 and 223 then you have a class C network, and
> the link address is just D.  If A is less than 128 and B is non-zero, you
> can't use this driver.
Thanks for the suggestion. I have updated the doc accordingly.
Ben
Re: HP E2050A LanGpib gateway driver Ian Smith
HP E2050A LanGpib gateway driver Mathew Rippa
Re: HP E2050A LanGpib gateway driver Andrew Johnson
Prev: CA throughputs Lifang Zheng
Next: Re: CA throughputs Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: HP E2050A LanGpib gateway driver Andrew Johnson
Next: Re: HP E2050A LanGpib gateway driver Ian Smith
