1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: C++ API backwards compatibility
To: [email protected]
Date: Fri, 08 Dec 2000 17:15:37 -0500
Andrew Johnson wrote:
> places).  In the above case, if no suitable comparison operator (cit !=
> it) exists then the compiler will automatically convert the RHS to cit and
> use (cit != cit).
  Nope.  That's my whole point.  While the standard does allow for
explicitly converting an iterator to a const_iterator, there is no
special rule for implicit conversion, just the regular C++ rules
for resolving overloaded template functions.  See section 14.8.3.
> My current list implementation allows either order in comparisons, but I
> could take out the (it == cit) operations if you really think this is
  If your operators are friend functions, the only way this will compile
with HP's aCC is by explicitly casting; order is of no consequence:
        (cit == (const_iterator)it), or ((const_iterator)it == cit)
  On the other hand, if you define these operators as member
functions of iterator and const_iterator, there shouldn't be any
problem with template deduction.
Chris
Christopher A. Larrieu
Computer Scientist, Acc. Controls Group
Thomas Jefferson National Accelerator Facility
C++ API backwards compatibility Jeff Hill
Re: C++ API backwards compatibility Andrew Johnson
Re: C++ API backwards compatibility Chris Larrieu
Prev: Re: C++ API backwards compatibility Andrew Johnson
Next: HP E2050A LanGpib gateway driver Mathew Rippa
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
