1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: C++ API backwards compatibility
To: Chris Larrieu <[email protected]>
Cc: [email protected]
Date: Fri, 08 Dec 2000 14:57:25 -0600
Chris Larrieu wrote:
> The comparison between an iterator and a const_iterator is not
> defined by the standard.  The only portable solution is to
> cast my_list.end() to a const iterator:
>   if (it != (list<t>::const_iterator)my_list.end())
>     cout << "groovy" << endl;
The following should be portable:
  if (my_list.end() != it)
I suspect the Standard requires that a const_iterator can be implicitly
created from an iterator, although I don't know for sure (I can't find
very much about const_iterator in it, but I may be looking in the wrong
places).  In the above case, if no suitable comparison operator (cit !=
it) exists then the compiler will automatically convert the RHS to cit and
use (cit != cit).
> But, both g++ and MS VC++ quietly permit the first comparison,
> while the HP aCC compiler specifically disallows it, specifically
> because it's undefined.  You might take this in one of two ways:
> either as evidence that HP is behind the times, or that HP avoids
> supporting de facto standards.
My current list implementation allows either order in comparisons, but I
could take out the (it == cit) operations if you really think this is
necessary.  I'm not sure that we'll be switching over to vendor's list
classes for quite a long time though - Tornado 2 is the worst performer,
and I can't see that being updated anytime soon.
- Andrew
Every great idea appears crazy to start with.
Re: C++ API backwards compatibility Chris Larrieu
C++ API backwards compatibility Jeff Hill
Re: C++ API backwards compatibility Andrew Johnson
Prev: Re: C++ API backwards compatibility Chris Larrieu
Next: Re: C++ API backwards compatibility Chris Larrieu
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
