Steven Hartman wrote:
> The system is an MVME167, vxWorks 5.4, kernel 2.5, tornado 2. VxWorks was
> built with INCLUDE_SECURITY defined, and I specified in configAll.h a
> LOGIN_USER_NAME and a LOGIN_PASSWORD (generated with vxencrypt on a
> solaris 7 host). I have confirmed that rlogind and telnetd are running on
> the ioc.
> Connnecting via a console port to the crate works fine and everything
> appears to be functioning correctly.
> However, telnet or rlogin to the crate results in "Login Incorrect" using
> the specified user name, passwd pair.
Are you sure you're using the right version of vxencrypt for your vxWorks
image? I seem to remember that WRS changed the password encryption
recently, maybe in a patch file, because it wasn't making use of the first
character or something like that. Should you be using a version of
vxencrypt from a different tornado release then you'll see the problems
you're getting. Do a which vxencrypt and/or use an explicit pathname to
the tornado version that you're booting and see if you get a different
encrypted string.
- Andrew
Every great idea appears crazy to start with.
- VxWorks login authentication Steven Hartman
Re: VxWorks login authentication Steven Hartman
<2000>
<2000>
