> We use x-terminals (Open-Windows now but CDE soon) to display medm_2.3.4a
> displays. When the operator minimizes the display to an icon, the icon
> label is the .adl file's name, left-justified, including the full
> pathname. So , the icon labels are the same for all medm displays, showing
> the very top few directories in the path.
> Is there a way to right-justify the icon label (xset?) and/or a way to
> specify the icon label's text (medm command line?) ?
This happens when you open a .adl file from the "Open" dialog. The
"selection" text includes the full path to the file. If you clear it, and
type in the name of the file you want to open, or select one from the list
and then delete the leading path elements, the icon name will be just the
file name. Note that this only works if the file you want to open is in
the directory which was the current working directory when MEDM was run.
Ken:
The window title is set using medmSetDisplayTitle(), which strips off the
leading path, while the icon name is just set to displayInfo->dlFile->name,
which includes the full path.
Brian McAllister Controls Programmer/Beam Physicist
[email protected] MIT-Bates Linear Accelerator
(617) 253-9537 Middleton, MA
- Re: medm icon Pete R. Jemian
- medm icon Paul Sichta
Re: medm icon Ken Evans
compiling seq-1.9.5 with WIN32 Benjamin Sailer
<2000>
<2000>
