Thx Nick
I'll take it and, I think I can solve the problem. I had to do a similar
thing for some motor control on an instrument. After I test it I will
give it back.
FTP?
AH
> From [email protected] Mon Apr 17 12:39:02 2000
> Hi Alan,
> > Has anyone ported the tnet driver to Unix?
> I did a bit of work on this a few months ago. It was fairly simple - it
> just needed a new initialization routine, everything else worked. I only
> tested it on Solaris. I can let you have the code.
> However, I ran into a problem and never got back to it - so I never used
> it with real hardware. I was always meaning to ask tech-talk about it, so
> here goes.
> Does anyone have a good set of routines for turning off line mode in a
> standard Unix terminal driver (i.e. turning on the equivalent of the
> VxWorks OPT_RAW mode). My problem with the tnetDrv code was that I
> couldn't get the psuedo terminal to go into character mode. I looked
> through all the ioctl codes on Solaris and couldn't find anything that
> looked right, but on the other hand most of the standard communication
> packages use character mode and so it obviously can be done - I just
> couldn't find the codes. The answer must be bleeding obvious, but since I
> have never done this sort of thing before, I got stuck.
> So, can someone help me.
> Cheers,
> Nick Rees
> Joint Astronomy Centre Ph: +1 (808) 961-3756
> 660 N. Aohoku Place Fax: +1 (808) 961-6516
> Hilo, HI. 96720 Internet: [email protected]
Re: tnet driver Nick Rees
Re: tnet driver Jim Thomas
<2000>
MATLAB Song, Jinhu
<2000>
