1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS R3.13.1 and Power PC
To: Vladis Korobov <[email protected]>
Cc: [email protected]
Date: Wed, 22 Mar 2000 10:43:13 -0600
Vladis Korobov wrote:
> I work with EPICS R3.13.1, vxWorks 5.3.1.
> I started to work with Power PC board (mv2306). When I tried to build
> EPICS base I got following compilation error in base/rsrv:
There is probably due to a known problem with the vxWorks header files
when building for Tornado 1.0.1 on the PowerPC.  The fix for this has been
included in the R3.13.2 configuration files, and involves changing a line
in config/CONFIG.Vx.ppc604 so the following definition appears:
	ARCH_DEP_CPPFLAGS = -DCPU=PPC604 -D_GNU_TOOL -DTRUE=1
The -DTRUE=1 is the important factor here; the architecture-specific
var-args header file for the PowerPC requires that the TRUE macro be
defined, which isn't always the case.
- Andrew
Complexity comes for free, Simplicity you have to work for.
EPICS R3.13.1 and Power PC Vladis Korobov
Prev: Re: Who is using what EPICS version Janousch Markus
Next: Re: compiler bug in unpatched Solaris C++ 5.0, Visual C++ Kay Kasemir
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS R3.13.1 and Power PC Vladis Korobov
Next: utilities for counting and sorting .db files Rozelle Wright
