1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VxWorks global variable device support (capfast can default DOL to not set)
To: [email protected], [email protected], [email protected], [email protected]
Date: Thu, 3 Feb 2000 13:08:40 -0700 (MST)
Hi William,
Our symbols are the same size as yours, because we originally got them from
you, so we could exchange schematics and they would still fit.
(The symbols from jlab are a different size.)
However, our users thought that displaying NPP/PP by
default cluttered up the schematics, so in most cases we display PP if that
is what we are using and if nothing appears it is NPP.  Of course if we
forget to turn display on for PP the schematic is misleading.
Rozelle
> From [email protected] Thu Feb  3 12:08 MST 2000
> Date: Thu, 3 Feb 2000 09:08:40 -1000
> X-Sun-Charset: US-ASCII
> Content-Type: text
> Content-Length: 601
> X-Lines: 16
> Dear all,
> Both Ben and Rozelle report having changed Capfast symbols so that DOL
> defaults to "undefined". We have changed Capfast symbols here too
> (although not in any way that could affect behavior I believe).
> So we all have our own versions of these symbols (this came up at the
> last LANL collaborators' meeting). Is there any prospect of once again
> all using the same symbols? The answer may just be a simple 'no'. I know
> of two things that we changed which would not be generally acceptable:
> 1. we label DOL, INP and OUT fields with their PP attribute
> 2. we add a PV:$(name) property
> William
Re: VxWorks global variable device support (capfast can default DOL to not set) Nick Rees
Prev: Re: VxWorks global variable device support (boRecord.c) saa
Next: Re: VxWorks global variable device support (capfast can default DOL to not set) Nick Rees
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VxWorks global variable device support (capfast can default DOL to not set) William Lupton
