1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: bug in EPICS R3.13 and R3.12---booting vme162
To: [email protected] (Lin Jie)
Cc: [email protected] (EPICS Tech-Talk)
Date: Mon, 26 Jul 1999 11:58:36 +0200 (METDST)
> I changed my host computer from tcsh back to csh,
Why? Is there a good reason to do this backward step?
For performance reasons I would suggest having the IOCs boot with a user
name that has /bin/sh as login shell, anyway. Being a shared excutable,
the /bin/sh binary will very likely be already running on the host, i.e.
it will already be in memory. Plus, usually /bin/sh is the fastest shell
in terms of time needed for startup/login.
> and I found all the 162s that are booting from my host stop
> loading. Two different cases: One is if my IOC using the rsh, then it
> will say "bus error" and print out bunch of things.
We had a similar csh/tcsh shell related problem that we tracked down to
the PATH variable being limited in length (1024 chars, iirc).
> The other is if my ioc is using the ftp (user name + passwd), then it
> will hang up when it tries to load the VxWorks symbols.
This is due to a bug in the mv162 BSP: Even if you tell the IOC to boot
using ftp, the symbol table still will be loaded using rsh access. (So
you're running into the first case error again.)
> What really bothers me is that this only happens to 162. I have 167s
> as well which are using rsh. It has the same "bus error",
Which definitely makes it look like a host computer csh problem more
than an IOC problem ...
> but when I put in the passwd to use the ftp, then it loads no problem.
So the mv167 BSP doesn't seem to have the mv162 bug. Good.
> Hope someone out there could shed some light on this murky situation
> for me.
Well, I tried ...
Ralph
bug in EPICS R3.13 and R3.12---booting vme162 Lin Jie
Prev: bug in EPICS R3.13 and R3.12---booting vme162 Lin Jie
Next: Re: How do you know if you are accessing a shared resource? Marty Kraimer
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: bug in EPICS R3.13 and R3.12---booting vme162 Andrew Johnson
