1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: OMS Support
To: Andy Foster <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Thu, 04 Mar 1999 16:21:33 -0600
Andy Foster wrote:
> Dear All,
> Apparently OMS are replacing the VME8-8 with VME58-8.
> Is anyone using the new card with EPICS 3.12.2?
A number of experimenters at the Advanced Photon Source
have been using the OMS VME58-8 since I have been here
(1/98) without any major problems.
> Can anyone tell me if the EPICS driver supports this new card without
> changes?
Of course, there are always changes.
Support for the OMS VME58-8 extends back to at least
Motor Record version 2.3; I don't know if any earlier
versions of the Motor Record supported the VME58.
The differences between the "oms" and "oms58" device
drivers are minor in terms of the "st.cmd" file.  Simply
add an additional setup line for the "oms58" as follows,
# OMS VME driver setup parameters:
#     (1)cards, (2)axes per card, (3)base address(short, 16-byte
boundary),
#     (4)interrupt vector (0=disable or  64 - 255), (5)interrupt level
(1 - 6),
#     (6)motor task polling rate (min=1Hz,max=60Hz)
omsSetup(5, 8, 0xFC00, 180, 5, 10)
# OMS VME58 driver setup parameters:
#     (1)cards, (2)axes per card, (3)base address(short, 4k boundary),
(1 - 6),
oms58Setup(5, 8, 0x3000, 190, 5, 10)
Please be aware that there are some known problems with
earlier Motor Record releases (i.e., anything before
Version 3.4).  See below for problem description,
http://www.aps.anl.gov/xfd/SoftDist/swBCDA/motor_V3.4.html
As long as we are on the topic of OMS VME58 boards;
Attention anyone out there with OMS VME58-8S boards.
OMS has upgraded EPROM U78 to BV52.2-8S.  This
fixes a bug that caused the VME58-8S board to be
unavailable on the VME bus every other time after
a VMEbus System Reset.
Ron Sluiter
OMS Support Andy Foster
Prev: OMS Support Andy Foster
Next: Re: OMS Support Tim Mooney
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
