1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Links between IOCs
To: "Rivers, Mark L." <[email protected]>, "Hammonds, John" <[email protected]>
Cc: [email protected]
Date: Fri, 11 Dec 1998 13:30:46 -0600
This suggestion from Mark has done the trick.  According to some E-mails
that I have seen it seems somewhat random when this is needed.  Does anyone
know why things work sometimes and not others?
John
> -----Original Message-----
> From:	Mark Rivers [SMTP:[email protected]]
> Sent:	Thursday, December 10, 1998 8:14 PM
> To:	[email protected]
> Cc:	[email protected]; [email protected]
> Are you sure that CA links between IOCs are working at all?  You need to
> put
> lines in your st.cmd like the following:
> # Set the default gateway
> routeAdd "0","164.54.160.65"
> # Don't use the gateway for machines on this subnet
> routeDelete "164.54.160.64","164.54.160.65"
> Mark Rivers
Prev: Re: Monitors Brian McAllister
Next: Re: Monitors Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Links between IOCs Maren Purves
Next: RE: Links between IOCs Jeff Hill
