Subject: |
enhancements to Andrew Johnson's IPC driver |
[email protected] (Jeff Hill) |
To: |
"EPICS-tech-talk (E-mail)" <[email protected]> |
Date: |
Thu, 3 Dec 1998 12:10:04 -0700 |
All,
1) I propose that the following routine be added to Andrew Johnson's
IPAC library so that we can use ISA based IPAC carriers without
allowing architecture dependent interrupt vectoring to leak into
our IPAC module drivers.
int ipmIntVecConnect (
unsigned carrier,
unsigned slot,
unsigned vector,
void (*pIntServiceFunc)(void *pIntServiceParam),
void *pIntServiceParam);
This will allow unmodified IPAC module drivers to function properly on multiple
IPAC carrier boards that are not necessarily hosted on the same IO bus. Of course
this will also require a new entrypoint in the carrier driver jump table. Note that the ISA
bus does not support interrupt vectoring so we will implement this functionality in the
ISA carrier board driver.
2) I propose that the master source for Andrew Johnson's IPAC driver be moved
into the CVS repository at APS under a new drivers directory so that it can easily be
maintained by multiple sites.
Jeff
______________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
- Re: enhancements to Andrew Johnson's IPC driver Marty Kraimer
RE: ????kernel work queue overflow error???? Mark Rivers
PC Fonts.... Bonnie Madre
<1998>
<1998>
