1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stops in the motor record
To: [email protected]
Date: Mon, 30 Mar 1998 16:41:10 -0600
Hubert, re...
> -- On Mar 27, 1998, [email protected] (Tim Mooney) wrote
> > I should mention that glitches on the limit-switch lines can produce
> > very similar behavior, and are by **far** the more common cause of it.
> > So don't everybody with an intermittently jerky motor immediately assume
> > their hardware is flakey.  You might just need some decoupling capacitors.
> I'm not sure that this is true.  I've seen this behavior very regularly
> (with the .27 release of the motor record, VME8-8 board).  I don't have
> any limit switches in my system and limit-switch support has not been
> enabled.
Wait a minute.  You can't enable or disable limit switch support, and the
hardware doesn't care whether or not you actually have switches.
Tim
Re: Stops in the motor record larry
Prev: CA Server john sinclair
Next: Re: Stops in the motor record larry
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Stops in the motor record Guy Jennings
