1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stops in the motor record
To: "tech-talk" <[email protected]>
Date: 30 Mar 98 15:21:14 -0600
         Reply to:   Re: Stops in the motor record
This may explain a puzzling problem we have seen where the first point in a motor scan is wrong.  I had thought it was a problem with my own code!
Now, all we need is for someone to fix it!!!
Graham Waters wrote:
>Janet Tvedt wrote:
>> >> To users of the motor record:
>> >> This code segment from recMotor.c is causing me some problems.  Stops are >issued
>> when they should not be.  I think this is happening because the axis is >queried
>> before it has started moving and the last move was in the opposite >direction from
>> the current move.
>> >> Has this been a problem for others?  What would you recommend doing to fix it?
>I have seen this behavior in the following motor record distribution
>(www.aps.anl.gov/xfd/SoftDist/swBCDA/xfdApp R3.13.0.beta7
>unbuilt.tar.gz)
>It has puzzled me but I have no time to investigate the problem, Glad
>I'm
>not the only one to see it.
>|Graham Waters, Control System Eng          Internet: [email protected]|
>|TRIUMF --- University of British Columbia,    phone: (604)-222-1047  |
>|Vancouver, BC, Canada                           Fax: (604)-222-7307  |
>|http://sunset.triumf.ca/homepage/graham01.html                       |
>RFC822 header
>Received: from dns2.anl.gov (dns2.anl.gov [146.139.254.3]) by >pop.msd.anl.gov (8.8.7/8.6.11) with ESMTP id RAA05320 for <[email protected]>; Thu, 26 >Mar 1998 17:03:42 -0600 (CST)
>Received: from epics (epics.aps.anl.gov [164.54.8.141]) by dns2.anl.gov >(8.8.7/8.6.11) with SMTP id RAA14152; Thu, 26 Mar 1998 17:04:08 -0600 (CST)
>Received: from REG.TRIUMF.CA by epics (SMI-8.6/SMI-SVR4)
>	id QAA16709; Thu, 26 Mar 1998 16:55:06 -0600
>Received: from triumf.ca (edevel6pc.Triumf.CA) by Erich.Triumf.CA (MX V4.0-1
>          VAX) with SMTP; Thu, 26 Mar 1998 14:54:57 PST
>Message-ID: <[email protected]>
>Date: Thu, 26 Mar 1998 14:55:57 -0800
>From: Graham Waters <[email protected]>
>Reply-To: [email protected]
>Organization: TRIUMF
>X-Mailer: Mozilla 4.03 [en] (Win95; I)
>MIME-Version: 1.0
>References: <[email protected]>
>Content-Transfer-Encoding: 7bit
>Content-Type: text/plain; charset=us-ascii
>Content-Length: 1090
>Status:   >
Prev: Re: Stops in the motor record Hubert Yamada
Next: CA Server john sinclair
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Stops in the motor record Tim Mooney
