1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stops in the motor record
To: [email protected]
Cc: [email protected], [email protected]
Date: Fri, 27 Mar 1998 11:20:23 -0700
Did you try powering off and on your IOC.  Sometimes the OMS
controllers get in a wierd state that is difficult to correct.
It appears to work for me.  However, the auxillary output is not
turned off.  AF turns it on and AN should turn it off.  The AN
works fine for moves in the positive direction, but not in the
negative direction.  This makes no sense and I had not noticed
it until now.
sent message (AX AF VB37 VL2048 AC1024 MR-723 GD AN IP
sent message (AX QA RP RE EA
Janet
Janet Tvedt, Engineering Technical Services     Internet: [email protected]
National Optical Astronomy Observatories        Phone:    (520) 318-8388
950 N. Cherry Ave., Tucson, AZ  85719           FAX:      (520) 318-8360
> I tried it and Tim's 5/29 modification does not correct the premature
> stopping problem. I don't think it is a timing problem either. I
> slowed the motor polling task's scan rate down to once a second and
> that first RP always returns the previous moves direction.
> Ron Sluiter wrote:
> > That code fragment was changed by Tim Mooney with release 3.13.0.beta7
> > to the following:
> Joe
> Joseph Sullivan                        Phone:    (630) 252-8657
> Experimental Facilities Division       Email:    [email protected]
> Argonne National Laboratory            Fax:      (630) 252-9303
> 9700 S. Cass Ave. Bldg. 401
> Argonne, IL  60439-4844
Prev: Re: Stops in the motor record Joseph P. Sullivan
Next: Re: Stops in the motor record Tim Mooney
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
