1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stops in the motor record
To: [email protected]
Cc: [email protected]
Date: Fri, 27 Mar 1998 12:27:32 -0600
re...
> I tried it and Tim's 5/29 modification does not correct the premature
> stopping problem. I don't think it is a timing problem either. I
> slowed the motor polling task's scan rate down to once a second and
> that first RP always returns the previous moves direction.
The modification affects only motors *using* encoder (or readback-link)
feedback.  Janet's hardware has encoder support, but it's not being used, so
midcourse corrections would be done even with the current version of the
motor record.
I should mention that glitches on the limit-switch lines can produce
very similar behavior, and are by **far** the more common cause of it.
So don't everybody with an intermittently jerky motor immediately assume
their hardware is flakey.  You might just need some decoupling capacitors.
Tim
Prev: Re: Stops in the motor record Janet Tvedt
Next: [no subject] Bill Brown
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Stops in the motor record Hubert Yamada
