1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS r3.13 field VERS and RTYP
To: [email protected]
Date: Tue, 03 Feb 1998 13:34:20 -0600
Let me summarize the situation:
There are at least two ways to allow CA clients to retrieve the record
type and a version identifier for a record type/record support
combination:
1) Add two new fields RTYP and VERS
2) Add two new DBR_types
Here are arguments for/against each
New fields RTYP and VERS
Argument for:
Existing CA clients automatically have access to new info.
Arguments against:
1) Each record instance will use extra storage for new fields.
2) Not elegent, i.e. info is associated with record instances that
belongs to record type.
3) A CA client that wants to provide a builtin capability to get record
type/version must know how to strip field name from channel name and
then add .RTYP or .VERS
New DBR_types: Arguments for/against are the reverse of those for new
fields.
I am starting to think that allowing existing CA clients to work without
change is more important than the other arguments.
For Channel Access Version 4 and database Access version 4 we should
solve these problems in a much nicer way but maybe for version 3 adding
new fields is best.
Marty Kraimer
Re: EPICS r3.13 field VERS and RTYP Chip WATSON
Re: EPICS r3.13 field VERS Marty Kraimer
Prev: Re: proposed RTYP field Marty Kraimer
Next: Re: EPICS r3.13 field VERS Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS r3.13 field VERS Marty Kraimer
Next: Re: EPICS r3.13 field VERS and RTYP Chip WATSON
