> I added the CONVERSION_REQUIRED define (along with MULTINET and
> "caNetAddrSock") to my cxx command and the example server now works
> great and data looks good. And of course, /float=d_float just like
> for the client. This solution can be made permanent as far as I'm
> concerned. Thanks,
Yes, sorry I had a temporary bit of amnesia, and you are correct. In fact gdd
does not currently handle floating point conversion, but the CA server does if
CONVERSION_REQUIRED is defined because it will then use the host format
to network format conversion code that is built into the CA client library. This
change was added when we were porting to the PC environment to solve
endian problems, and so I didn't immediately leap to the conclusion that the VMS
floating point conversion problems had been solved.
Jeff
Re: Running CA Server on VMS - Data Conversion Problem saa
Re: proposed RTYP field Marty Kraimer
<1998>
alh group reset mask question William Lupton
<1998>
