1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Running CA Server on VMS - Data Conversion Problem
Cc: [email protected]
Date: Mon, 02 Feb 1998 16:41:18 -0800 (PST)
>> I'm running the simple example CA server on my VMS machine (ca and cas
>> from beta11).  I can connect and get data from it except that the
>> floating point data is incorrect, probably because VMS floats are
>> different from the rest of the world.  Perhaps this is just a build
>> problem.
>This is hopefully  the last major issue that needs to be resolved in the VMS port of the
>ca server.
Hi Jeff -
I added the CONVERSION_REQUIRED define (along with MULTINET and
"caNetAddrSock") to my cxx command and the example server now works
great and data looks good.  And of course, /float=d_float just like
for the client.  This solution can be made permanent as far as I'm
concerned.  Thanks,
Stephanie
Prev: RE: Running CA Server on VMS - Data Conversion Problem Jeff Hill
Next: RE: Running CA Server on VMS - Data Conversion Problem Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
