1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ai record support has an error
To: [email protected]
Date: Mon, 20 Oct 1997 13:36:17 -0500
Benjamin Franksen wrote:
> Hi Folks,
> it's been quite a few weeks ago when one of my colleagues (Goetz
> Pfeiffer) had a problem with the ai record and another one (Jens Bergl)
> proposed a _very_ simple solution. The problem concerns the record's
> behavior when it does linear conversion from a 32 bit raw value to an
> analogue (double) value.
> The formula
>         val = (rval + roff) * eslo + egul
> is implemented in the ai record support inside the function convert().
> Here, the first thing that happens is
>     val = pai->rval + pai->roff;
> which leads to an overflow (and thus to an incorrect pai->val) if the
> raw value uses all 32 bits and the egul/eguf values are (for example)
> min(long) and max(long). This is because the calculation uses long
> arithmetic. A simple cast _before_ the calculation like
>     val = (double)pai->rval + (double)pai->roff;
> solves the problem (one of the casts would do).
>         Ben
This change will appear in the next release.
Marty Kraimer
Re: ai record support has an error Benjamin Franksen
Prev: ai record support has an error Benjamin Franksen
Next: Subarray records with a minummum profile Hammonds, John
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: ai record support has an error Benjamin Franksen
