1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Subarray records with a minummum profile
To: [email protected]
Date: Mon, 20 Oct 1997 16:03:50 -0500
I am looking at using EPICS for a data acquisition system for an array
of detectors.  We are thinking of using subArray records to hold the
data but need some flexibility that does not seem to be worked in.
First of all we will routinely rebin the array from one run to the next
so that it would be nice to resize the array on the fly.
We often combine data on the fly to conserve memory.  Again, we change
how this is done on the fly.
To get around the resizing problem I was thinking about defining one
large subArray record that would predefine the entire data space for the
crate.  I would then use a subArray record that points into the larger
dataspace to allow access data for each detector.  For now I can limit
myself to the 16KB limit for CA transfers within this limit.  This also
allows data to be binned together on the fly since two of the smaller
subArrays can point to the same space.
One problem that I have with this is that the smaller subarrays seem to
copy the data from the larger subArray to the smaller one.  This seems
to be a waste of both time (for copy) and memory for this purpose.  What
I was thinking of doing was making the BPTR of the smaller array point
directly to the BPTR of the larger array (+the INDX offset).
Has anyone done this or does anyone see a problem/improvement with this
approach?
John P. Hammonds
Intense Pulsed Neutron Source
Argonne National Laboratory
(630)252-5317
Prev: Re: ai record support has an error Marty Kraimer
Next: Re: ai record support has an error Benjamin Franksen
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Subarray records with a minummum profile Tim Mooney
