1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Bad CALC record kills IOC
To: [email protected]
Date: Mon, 07 Jul 1997 09:53:52 -0500
Bob Dalesio wrote:
> I think it would be nice if the record was able to detect this
> and set it's status to BAD_CALC and not take a dirt nap. Do you
> have a copy of the expression that did the dirty deed.
>         Bob
Done. This will be in next 3.13 release.
The fix involved adding one to all defines in post.h
so that it could start:
#define         BAD_EXPRESSION  0
#define         FETCH_A         1
#define         FETCH_B         2
#define         FETCH_C         3
postfix.c and calcPerform were changed to use BAD_EXPRESSION.
This means that ANY record type that uses calcPerform should
work if it meets two conditions:
1) The array holding the reverse polish notation is initialized
   to start with a null. (This is automatically done if a field
   defined in the dbd file is used).
2) The record type checks the return code from calcPerform, i.e.
   it has code similar to the following:
if(calcPerform(&pcalc->a,&pcalc->val,pcalc->rpcl)) {
     recGblSetSevr(pcalc,CALC_ALARM,INVALID_ALARM);
} else pcalc->udf = FALSE;
What made things crash before was:
1) FETCH_A was defined to be 0
2) The array holding the rpn was initialized to nulls.
This meant that calcPerform got something that looked
like an expression starting with a bunch (at least 200) of FETCH_A.
I did not look hard enough to see what happened next but I can
imagine really bad things.
Marty Kraimer
Re: Bad CALC record kills IOC Bob Dalesio
Prev: Re: Bad CALC record kills IOC Marty Kraimer
Next: SGL encoder in EPICS Noboru Yamamoto
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Bad CALC record kills IOC Bob Dalesio
Next: Re: Bad CALC record kills IOC Bob Dalesio
