1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IP support
Date: Fri, 13 Dec 96 10:53:54 -0500
RE: HIDEOS and EPICS
Jim,
One difficulty with using Hideos is needing a 2nd CPU.  I'm not sure how
well running Hideos under VxWorks is supported -- care to elaborate?
One experience we have is that we are running (Alicia, feel free to chime
in here) a different VxWorks kernel and/or EPICS kernel for the 1 system
we are running with Hideos (successfully, in production use I might add).
Perhaps that is no longer true at APS, but we are not well connected with
these developments, perhaps, which just points out the difficulty of
us using Hideos or DESY's generic device interface.
On a more philosophical note, is it appropriate to insert Hideos (message
passing) to control a simple register based IP ADC?  Can we not come up
with a better abstract driver interface with extremely low overhead for
such devices?  DESY also has a generic interface, but it, too, seems heavy
weight for simple devices.
I would be estatic if we could merge all of these developments, but it would
require all the relevant developers to stop work on other projects, and focus
exclusively on this problem for a month, plus effort to change some amount
of existing code.  I think other systems have better standards at this
level (LabVIews, National Instruments), and EPICS could stand some real
improvements here.  Takers, anyone?
Chip
Prev: IP support Jim B. Kowalkowski
Next: RE: IP support CLAUS
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
