> I have an application where I want to connect a PP output link (of a
> genSub record) to the VAL field of a passive ao record...
> Silly me... I hadn't read the README. You connect to the SLNK field (I had
> thought that you could only connect FLNK to SLNK).
> I thought you were supposed to link to the SVAL field? (artificial name for
> the VAL field which CAPFAST treats as in IN instead of an OUT)
> Chip
> The SVAL port was added to the CEBAF symbols
> but is not provided by the symbols
> currently in use at APS, LANL and by the astronomy
> community. The SLNK port works identically to the SVAL port,
> though using the latter would provide more meaningful documentation.
> Rozelle
I've actually done this sort of thing a lot (using a PP link from an OUTLINK
field to a VAL field). My favorite method is to use one of the "large" or
"medium" symbols for the ao record and define one of the "user-defined" input
links (FLD0, FLD1, etc.) to be VAL. The latest versions of e2sr/e2db do not
mind if VAL is defined as both an input and output.
Eric Bjorklund
Los Alamos Neutron Science Center
Re: Capfast question: linking to ao .VAL field? Rozelle Wright
VME: Cannot find record type dfan Marian Zurek
<1996>
Re: Portable Channel Access Server Jeff Hill
<1996>
