1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Portable Channel Access Server
To: [email protected]
Cc: [email protected]
Date: Wed, 11 Dec 1996 16:52:55 -0700
Steve Hunt wrote:
> Does anyone have any portable channel access examples ?
Look in 3.13 under $(EPICS)/base/src/cas/example. Jim will
be adding an additional example to the cas directory
in the next beta release of 3.13. The CA gateway might
server as a more complex example (when it is ready for release).
> If so for which platforms has it been tried ?
So far we have compiled on the following platforms:
sunos4 {sun pro C++, GNU C++}
solaris {sun pro C++, GNU C++}
windows{NT,95} {MS vis C++} - no little endian support in gdd
HPUX {GNU C++ - native compiler has not been tried}
The "gdd" self describing data class library does not yet
support little endian architectures. Otherwise all little
endian support is in the server library.
I am close with multi-threaded/vxWorks specific portions of the
code but this may be held up for a few months while other
higher priority activities are completed (this is mostly a matter
of making the library thread safe).
We are working on the doc.
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Portable Channel Access Server Steve Hunt
Prev: Portable Channel Access Server Steve Hunt
Next: Re: Capfast question: linking to ao .VAL field? watson
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: More Than One Way To Stuff a .VAL Eric Bjorklund, NPSM
