1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Burt under Solaris
To: Rolf Keitel <[email protected]>
Cc: [email protected]
Date: Fri, 06 Dec 1996 12:22:36 -0700
Rolf Keitel wrote:
> Hello all,
>         I am trying to build release R3.12.2.patch6 under Solaris and
> can't get Burt to build. Compilation seems to go fine, but then I get
> a large number of undefined name-mangled symbols. I have the SUN
> ANSI C compiler, and gnu. How do I do this right?
Make sure that all of the C++ involved is compiled with the
same C++ compiler. Perhaps the compiler is gnu g++ and one of
the C++ libraries is compiled with the sun pro compiler? It
should be ok to mix g++ and the sun ANSI C compiler however.
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Burt under Solaris Rolf Keitel
Prev: Burt under Solaris Rolf Keitel
Next: Capfast question: linking to ao .VAL field? William Lupton
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
