Argonne National Laboratory
1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Force Sparc 5 Performance Tests
To: tech-talk@aps.anl.gov
Cc: alles@cfht.hawaii.edu, cruise@cfht.hawaii.edu
Date: Mon, 21 Oct 1996 10:04:06 -1000
Jeff Hill writes:
 > It might be interesting to run catime over the network also -
 > say when the client is on a SPARC IOC and the server is on a different
 > SPARC IOC.
() indicates SPARC IOC to SPARC IOC performance across Ethernet.
Test                    Elapsed Time            Per Second
search test             0.000083 (0.002300)      12000 (  435)
float, async put test   0.000038 (0.000053)      26000 (19000)
float, async get test   0.000007 (0.000098)     140000 (10000)
float, synch get test   0.000083 (0.002333)      12000 (  430)
string, async put test  0.000057 (0.000073)      17500 (14000)
string, async get test  0.000022 (0.000093)      45000 (11000)
string, synch get test  0.000117 (0.002367)       8500 (  422)
integer, async put test 0.000035 (0.000052)      29000 (19000)
integer, async get test 0.000008 (0.000080)     120000 (12000)
integer, synch get test 0.000083 (0.002333)      12000 (  430)
free test               0.000033 (0.000017)      30000 (59000)
Aloha,
	Peregrine
Force Sparc 5 Performance Tests Peregrine McGehee
Prev: Re: GP-IB extended addressing support. John R. Winans
Next: re: CA c++ class library Fred Vong
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: Force Sparc 5 Performance Tests Peregrine McGehee
Next: Re: Force Sparc 5 Performance Tests Nick Rees
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
