1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Force Sparc 5 Performance Tests
To: [email protected]
Cc: [email protected], [email protected], [email protected]
Date: Thu, 17 Oct 1996 08:31:27 -1000
IOC:	Force Sparc 5 (frc5ce)
	VxWorks 5.2
	EPICS R3.12.0
I ran two tests, the first using the test database and MEDM
application suggested by Marty, and the second using the catime
program supplied with EPICS base.
Using the APS test database, I used the MEDM GUI to set the scan rate
of the master fanout record to ".1 second" which should have resulted
in the processing of 3000 records per second with associated monitors.
-> scanppl
Scan Period= 0.100000 seconds
    mrkfanout
value = 0 = 0x0
Here's the final output from 'spy' after a few minutes of
running. I've removed the tasks with 0 total ticks from the listing.
Note: The scanPeriod task at PRI:52 is a 20 Hz ".05 second" scanner.
No CA events were lost. The OPI is a HP 9000 Model 715/50.
NAME          ENTRY         TID   PRI   total % (ticks)  delta % (ticks)
tShell       _shell       ceb008    1     0% (       1)    0% (       0)
tSpyTask     _spyTask     cdead0    5     0% (     470)    0% (       6)
tNetTask     _netTask     ef8058   50     0% (     170)    1% (      12)
scanPeriod                cff460   52     0% (      21)    0% (       0)
scanPeriod                d01d78   53     4% (    2402)    0% (       3)
scanPeriod                d04690   54     0% (       9)    0% (       0)
scanPeriod                d06fa8   55     0% (       3)    0% (       0)
scanPeriod                d098a0   56     0% (       2)    0% (       0)
scanPeriod                d0c198   57     0% (       1)    0% (       0)
CA client    _camsgtask   ed0cc8  180     0% (     261)    0% (       7)
CA event     _event_tas   d18358  181     2% (    1227)    5% (      41)
CA online    _rsrv_onli   ed2988  183     0% (       2)    0% (       0)
KERNEL                                    0% (     139)    0% (       0)
INTERRUPT                                 0% (     237)    0% (       5)
IDLE                                     90% (   49697)   89% (     657)
TOTAL                                    96% (   54642)   95% (     731)
And here's the results from catime, after minor reformatting.
catime "xxx"
Soft Analog Input record, quiet system.
Test			Elapsed Time		Per Second
search test		0.000083		 12000
float, async put test	0.000038		 26000
float, async get test	0.000007		140000
float, synch get test	0.000083		 12000
string, async put test	0.000057		 17500
string, async get test	0.000022		 45000
string, synch get test	0.000117		  8500
integer, async put test	0.000035	         29000
integer, async get test 0.000008		120000
integer, synch get test 0.000083		 12000
free test		0.000033		 30000
Aloha,
	Peregrine
Peregrine M. McGehee			http://www.cfht.hawaii.edu/~mcgehee
Telescope Control Systems Group 	Canada-France-Hawaii Telescope
(808) 885-3178				P.O. Box 1597, Kamuela, Hawaii 96743
Prev: Re: FLAME medm watson
Next: Re: Force Sparc 5 Performance Tests Peregrine McGehee
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: GDCT under EPICS R3.13 Ric Claus
