David wrote:
> I'm trying to use dm colour rules to change the colour of a text monitor
> according to the value of a database field of type double. For values of
> 0.0 or greater this works fine but I can't get it to work with negative
> values; it behaves as if the expression is always false.
> The rule in the edd report looks like:
> name="test"
> info[0] {
> chan="$(C)"
> value="-1.0"
> connector="use"
> comparator="less than"
> clr="1"
> RISCpad="0"
> Should this work ? If not, is there any other way of doing what I want ?
> David Terrett Space Science Department
> Rutherford Appleton Laboratory
> [email protected] Chilton, Didcot
> Oxfordshire
> Tel: +44-1235-446478 OX11 0QX
> Fax: +44-1235-445848 United Kingdom
It should work. What version of edd/dm do you have? I'll
check it out.
Deb
Deb Kerstiens [email protected]
Phone (505)667-3396
LANL AOT-8,MSH820 PO Box 1663, Los Alamos, NM. 87545
dm colour rules with -ve values David Terrett
Re: CA connection Jeff Hill
<1996>
Re: A tool to support development of GP-IB device support routine. Noboru Yamamoto
Re: dm colour rules with -ve values Deb Kerstiens
<1996>
