William Lupton wrote:
> I suspect that you may not be using the "recursive" option. Without
> it, all state-program variables are simply statics and are therefore
> shared between instantiations. With it, each instance has a private copy
> of all variables. To set it, either use the "+r" flag to the "snc"
> command or else add the line
> option +r;
The example code already has the line allowing the recursive option.
option +r;
Andy reported back that I should upgrade to SNL 1.9.1.
Having done that, the problem is slightly different but
still does not work correctly. (That is, setting pj:debug1 = 1
allows output for task "test1" and not for task "test2" _but_
setting pj:debug2=1, with pj:debug1=0, does not allow any output
from either task.)
The problem still is not fixed by using SNL 1.9.1.
I think the flaw is with SNL
(or an incompatibility with SNL 1.9.1 and EPICS R3.12.2).
Thanks for the help,
Pete
Re: SNL 1.9 troubles William Lupton
<1996>
<1996>
