1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CALC record question
To: Epics Questions <[email protected]>
Date: Fri, 29 Mar 1996 17:48:19 +0000 (GMT)
Can anyone help me with the following:
I am trying to reset a value used in a calculation record
from a button on a 'dm' screen. The CALC field is set to
A+1 and the VAL field is looped back to INPA, so that continual
processing of the calculation record gives: 1, 2, 3, 4, etc.
I want a button on a 'dm' screen such that when it is pressed, the
above calculation starts again at 0. I thought this should be easy
but haven't managed it yet.
I tried letting the button press put the
value 0 into INPB and changing CALC to B*{A+1} so that,
normally B=1 and we have as before. When the button is
pressed, the record processes once with B=0 and then the
whole thing starts again.
This doesn't work.
I suppose because the above means that INPB needs to take two
inputs (the first, a hardwired 1, the second a 0 put into B when
the button is pressed).
In this case, how can the calculation record know which value it is
supposed to be using? Or am I going about this in totally the wrong way?
Any help would be greatly appreciated?
Cheers,
Andy
Andy Foster
Royal Greenwich Observatory	Tel:       44 (0)1223 374899 (direct)
Madingley Road			Fax:       44 (0)1223 374700
Cambridge			E-mail:    [email protected]
CB3 0HA				Home Page: http://www.ast.cam.ac.uk/~ajf
UK
Re: CALC record question Marty Kraimer
Prev: Porting EPICS onto new boards Ralph Lange
Next: Re: CapFast: New Menus / Rules Files Bret Goodrich
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: CALC record question Marty Kraimer
