1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Doc: Link Field Syntax
To: Marty Kraimer <[email protected]>
Cc: [email protected]
Date: Thu, 18 Jan 1996 15:57:07 +0000 (GMT)
On Thu, 18 Jan 1996 09:21:13 -0600 Marty Kraimer <[email protected]> wrote:
>Formerly the link info was not documented. In the next version of
>App Dev Guide it will be documented. On the EPICS WWW doc there
>is a heading "EPICS Work In Progress around the world". Under there
>is a document "Application Developers Guide Changes (postscript)".
>This is describing the NEXT release of EPICS so most of
>it does not apply to the current release. The description of what is
>allowed in link fields is, however, correct for the existing release.
Marty,
Can I make a suggestion about hardware addressing for a future ascii database
release, resulting from my having written a number of drivers in recent months?
I found the standard address types available to be somewhat restricting, so for
more than one driver I ended up using INST_IO to provides a string which I could
then parse for myself in the device or driver layer.  What would be really good
would be a way of allowing the device layer to define what format a hardware
address should take, rather than providing a fixed number of formats as at
present.
Obviously existing device support doesn't expect this, so it would probably be
necessary to provide the current formats to existing drivers somehow without
having to change them.  I haven't really thought about how you might specify the
address format, but it is something which I think could be incorporated into the
(very worthwhile IMHO) work you're doing.
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_      Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__   Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: Re: Doc: Link Field Syntax Marty Kraimer
Next: Re: Doc: Link Field Syntax Marty Kraimer
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
