1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Doc: Link Field Syntax
To: [email protected]
Date: Thu, 18 Jan 1996 09:21:13 -0600
> From [email protected] Thu Jan 18 08:25 CST 1996
> From: Ralph Lange <[email protected]>
> Subject: Doc: Link Field Syntax
> To: [email protected] (EPICS Tech-Talk)
> Date: Thu, 18 Jan 1996 15:21:41 +0100 (MEZ)
> Organization: BESSY GmbH, Berlin, Germany.
> X-Mailer: ELM [version 2.4 PL24]
> Mime-Version: 1.0
> Content-Transfer-Encoding: 8bit
> Content-Type: text/plain; charset=ISO-8859-1
> Content-Length: 382
> Hi all.
> One of my colleagues, who just started designing his database, asked me
> where to find a description of what he has to type into the hardware link
> fields, i.e. a description of the link field's syntax for the different link
> types.
> I didn't find anything --- did I miss something or has link.h been declared
> self-explaining (which IMHO would be at least disputable)?
> Ralph
If you use a databse configuration tool (dct gdct) it should prompt you
for what to enter.
Formerly the link info was not documented. In the next version of
App Dev Guide it will be documented. On the EPICS WWW doc there
is a heading "EPICS Work In Progress around the world". Under there
is a document "Application Developers Guide Changes (postscript)".
This is describing the NEXT release of EPICS so most of
it does not apply to the current release. The description of what is
allowed in link fields is, however, correct for the existing release.
Marty Kraimer
Prev: Doc: Link Field Syntax Ralph Lange
Next: Re: Doc: Link Field Syntax Andrew Johnson
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
