Now I have some time again to return to this one...
Michael, if I understand correctly, you would like to see a run-time test that the attribute PTHREAD_PRIO_INHERIT can actually be used to init a mutex? Have you really seen that pthread_mutexattr_setprotocol(&globalAttrRecursive, PTHREAD_PRIO_INHERIT) succeeds but the resulting globalAttrRecursive cannot be used to init a mutex? If yes, I find that behavior strange and unexpected.
Heinz, do you think I should add #define D_GNU_SOURCE somewhere in the code or should that be done in the configuration?
Concerning "mutex not owned by task": As a mutex is used to synchronize different tasks, there is no specific task "owning" it permanently. The task that has last locked it owns it, independent of the creator task. The only situation where I would expect such a message is if task A has locked it but task B tries to unlock it. Or no task has locked it but now it is unlocked. That has nothing to do which who created it. The problem in the MotorRecord originated in the wrong check of TryLock and thus a confusion which task owned the mutex at run time.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Heinz Junkes via Core-talk
Re: [Merge] ~bfrk/epics-base:remove-dbfl_type_rec into epics-base:7.0 Ben Franksen via Core-talk
<2021>
<2021>
