2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Subject: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0
From: Heinz Junkes via Core-talk <core-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Date: Mon, 04 Jan 2021 12:57:38 -0000
> Yes, even RTEMS5 without the new libbsd-network-stack has not defined
> _XOPEN_SOURCE and asks for the old implementation. I can set _XOPEN_SOURCE by
> hand and it works so far with it. But what I noticed in this context and I
> think that the mutexes may be used incorrectly in some modules and therefore
> it comes to problems such as: "mutex not owned by the task".
> I saw the whole thing in the context of MotorRecords (OMS):
> https://github.com/epics-modules/motor/issues/172
> I see a general problem that probably in some places mutexes are created in
> the iocInit task and then used afterwards in other tasks although the iocInit
> task has been terminated.
> As I understand it, mutexes should generally be created in the tasks in which
> they are also used? Or with shared memory the creating task must remain
> however existing?
If you build RTEMS with the POSIX_FLAGS like in Linux (-D_GNU_SOURCE -D_DEFAULT_SOURCE) then with the help of includes/sys/features.h  _XOPENS_SOURCE is defined to 700.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/394327
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Next: [Bug 1910148] [NEW] Broadcast address detection is unreliable on Linux Michael Ritzert via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024
Next: Re: [Merge] ~dirk.zimoch/epics-base:epicsMutexPriorityInheritance into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 26 Jan 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
