On 12/29/2017 08:55 AM, Mark Rivers wrote:
> I have run the runtests for windows-x64 and windows-x64-staticon VS2010.
> For windows-x64 there were no dialog boxes.
> For windows-x64-static there were many Debug Assertion error dialog boxes in testSerialization.t (24 times) and testPVScalarArrat (5 times)
> They all appear to be null pointer problems.
And yet they show as PASS? Strange. Can you capture a couple of these?
Maybe the first from each test for a start?
> Both also appeared to fail some tests:
At this point we need to see the output of the tests. Can you run:
> make tapfiles
Then collect the .tap files (test output) of the three mis-behaving tests.
These should be:
modules/database/test/std/O.*/simmTest.tap
modules/pvData/testApp/O.*/testSerialization.tap
modules/pvData/testApp/O.*/testPVScalarArray.tap
> These are failures on windows-x64:
> Test Summary Report
> simmTest.t (Wstat: 0 Tests: 1176 Failed: 7)
> Failed tests: 140, 315, 439-440, 665-666, 767
> Files=11, Tests=3575, 13 wallclock secs ( 0.48 usr + 0.08 sys = 0.56 CPU)
> Result: FAIL
> Failed 1/11 test programs. 7/3575 subtests failed.
> These are failures on windows-x64-static:
> Test Summary Report
> simmTest.t (Wstat: 0 Tests: 1176 Failed: 3)
> Failed tests: 355-356, 439
> Files=11, Tests=3575, 15 wallclock secs ( 0.50 usr + 0.03 sys = 0.53 CPU)
> Result: FAIL
> Failed 1/11 test programs. 3/3575 subtests failed.
> This is the output for windows-x64:
> H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64
> H:\epics-devel\base-7.0.1>make -s runtests
> Snippets.t .. ok
> All tests successful.
> Files=1, Tests=29, 2 wallclock secs ( 0.05 usr + 0.00 sys = 0.05 CPU)
> Result: PASS
> epicsUnitTestTest.t ........ ok
> epicsTypesTest.t ........... ok
> epicsInlineTest.t .......... ok
> epicsCalcTest.t ............ ok
> epicsAlgorithmTest.t ....... ok
> epicsMathTest.t ............ ok
> epicsMMIOTest.t ............ ok
> epicsEllTest.t ............. ok
> epicsEnvTest.t ............. ok
> epicsErrlogTest.t .......... 24/32 log client: connected to log server at "127.0.0.1:60935"
> epicsErrlogTest.t .......... ok
> epicsStdioTest.t ........... ok
> epicsStdlibTest.t .......... ok
> epicsSockResolveTest.t ..... ok
> epicsStringTest.t .......... ok
> epicsTimeTest.t ............ ok
> epicsTimeZoneTest.t ........ ok
> epicsThreadTest.t .......... ok
> epicsThreadOnceTest.t ...... ok
> epicsThreadPriorityTest.t .. ok
> epicsThreadPrivateTest.t ... ok
> epicsThreadHooksTest.t ..... ok
> epicsThreadPoolTest.t ...... ok
> epicsExitTest.t ............ ok
> epicsTimerTest.t ........... ok
> ringPointerTest.t .......... ok
> ringBytesTest.t ............ ok
> epicsEventTest.t ........... ok
> epicsMutexTest.t ........... ok
> epicsSpinTest.t ............ ok
> epicsAtomicTest.t .......... ok
> macDefExpandTest.t ......... ok
> cvtFastTest.t .............. ok
> macLibTest.t ............... ok
> macLib.t ................... ok
> taskwdTest.t ............... ok
> blockingSockTest.t ......... ok
> epicsMessageQueueTest.t .... ok
> epicsStackTraceTest.t ...... ok
> ipAddrToAsciiTest.t ........ ok
> osiSockTest.t .............. ok
> Files=40, Tests=4016, 200 wallclock secs ( 0.56 usr + 0.16 sys = 0.72 CPU)
> Result: PASS
> dbScanTest.t ............... ok
> dbShutdownTest.t ........... ok
> dbPutLinkTest.t ............ 265/320 dbJLinkInit: lexical error: invalid char in json text.
> {"x":bbbb}
> (right here) ------^
> dbJLinkInit: parse error: premature EOF
> {"z":{"good":6}
> dbPutLinkTest.t ............ ok
> dbLockTest.t ............... ok
> dbStressTest.t ............. ok
> testdbConvert.t ............ ok
> callbackTest.t ............. ok
> callbackParallelTest.t ..... ok
> dbStateTest.t .............. ok
> dbServerTest.t ............. 1/24 dbRegisterServer: 'one' registered twice?
> dbRegisterServer: Bad server name 'bad name'
> dbRegisterServer: Ignoring 'disabled', per environment
> dbUnregisterServer: Servers still active!
> dbUnregisterServer: 'toolate' not registered.
> dbUnregisterServer: 'no-routines' has no stop() method.
> dbServerTest.t ............. ok
> dbCaStatsTest.t ............ ok
> dbCaLinkTest.t ............. ok
> scanIoTest.t ............... ok
> dbChannelTest.t ............ ok
> dbChArrTest.t .............. Starting iocInit
> iocRun: All initialization complete
> dbChArrTest.t .............. ok
> chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
> chfPluginTest.t ............ ok
> arrShorthandTest.t ......... ok
> recGblCheckDeadbandTest.t .. ok
> testPutGetTest.t ........... ok
> dbStaticTest.t ............. ok
> Files=20, Tests=2856, 81 wallclock secs ( 0.41 usr + 0.11 sys = 0.51 CPU)
> Result: PASS
> msi.t .. ok
> Files=1, Tests=9, 1 wallclock secs ( 0.03 usr + 0.00 sys = 0.03 CPU)
> Result: PASS
> arrayOpTest.t ........... ok
> recMiscTest.t ........... ok
> linkRetargetLinkTest.t .. ok
> linkInitTest.t .......... 1/77 dbRegisterServer: 'rsrv' registered twice?
> linkInitTest.t .......... 18/77 dbRegisterServer: 'rsrv' registered twice?
> linkInitTest.t .......... 60/77 dbRegisterServer: 'rsrv' registered twice?
> linkInitTest.t .......... ok
> compressTest.t .......... 1/116 dbRegisterServer: 'rsrv' registered twice?
> compressTest.t .......... ok
> asyncSoftTest.t ......... ok
> softTest.t .............. ok
> asTest.t ................ ok
> analogMonitorTest.t ..... Starting iocInit
> analogMonitorTest.t ..... ok
> regressTest.t ........... 1/31 dbRegisterServer: 'rsrv' registered twice?
> dbConvertJSON: parse error: trailing garbage
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> regressTest.t ........... ok
> simmTest.t .............. Failed 7/1176 subtests
> Test Summary Report
> Result: FAIL
> tsTest.t .... ok
> dbndTest.t .. ok
> arrTest.t ... ok
> syncTest.t .. ok
> Files=4, Tests=1612, 3 wallclock secs ( 0.19 usr + 0.01 sys = 0.20 CPU)
> Result: PASS
> Base.t ........ ok
> Breaktable.t .. ok
> DBD.t ......... ok
> Device.t ...... ok
> Driver.t ...... ok
> Function.t .... ok
> Menu.t ........ ok
> Recfield.t .... ok
> Recordtype.t .. ok
> Registrar.t ... ok
> Variable.t .... ok
> Files=11, Tests=287, 1 wallclock secs ( 0.03 usr + 0.06 sys = 0.09 CPU)
> Result: PASS
> testThread.t ............ ok
> testEvent.t ............. ok
> testTimer.t ............. ok
> testBitSet.t ............ ok
> testOverrunBitSet.t ..... ok
> testByteBuffer.t ........ ok
> testBaseException.t ..... ok
> testSharedVector.t ...... ok
> testDebugPtr.t .......... ok
> testSerialization.t ..... ok
> testTimeStamp.t ......... ok
> testQueue.t ............. ok
> testTypeCast.t .......... ok
> testUnitTest.t .......... ok
> testjson.t .............. ok
> test_reftrack.t ......... ok
> testanyscalar.t ......... ok
> testBitSetUtil.t ........ ok
> testIntrospect.t ........ ok
> testPVType.t ............ ok
> testStandardField.t ..... ok
> testStandardPVField.t ... ok
> testPVData.t ............ ok
> testPVUnion.t ........... ok
> testConvert.t ........... ok
> testPVScalarArray.t ..... ok
> testPVStructureArray.t .. ok
> testOperators.t ......... ok
> testFieldBuilder.t ...... ok
> testValueBuilder.t ...... ok
> testProperty.t .......... ok
> testCreateRequest.t ..... ok
> testPVCopy.t ............ ok
> Files=33, Tests=2248, 12 wallclock secs ( 0.50 usr + 0.06 sys = 0.56 CPU)
> Result: PASS
> testAtomicBoolean.t ..... ok
> testHexDump.t ........... ok
> testInetAddressUtils.t .. ok
> configurationTest.t ..... ok
> testFairQueue.t ......... ok
> testWildcard.t .......... ok
> testChannelAccess.t ..... ok
> testCodec.t ............. ok
> testRPC.t ............... ok
> testServerContext.t ..... ok
> Files=10, Tests=6192, 30 wallclock secs ( 0.44 usr + 0.01 sys = 0.45 CPU)
> Result: PASS
> ntfieldTest.t ............... ok
> ntscalarTest.t .............. ok
> ntscalarArrayTest.t ......... ok
> ntnameValueTest.t ........... ok
> ntmultiChannelTest.t ........ ok
> ntscalarMultiChannelTest.t .. ok
> nttableTest.t ............... ok
> ntndarrayTest.t ............. ok
> ntmatrixTest.t .............. ok
> ntenumTest.t ................ ok
> ntunionTest.t ............... ok
> ntaggregateTest.t ........... ok
> ntattributeTest.t ........... ok
> ntndarrayAttributeTest.t .... ok
> ntcontinuumTest.t ........... ok
> nthistogramTest.t ........... ok
> ntutilsTest.t ............... ok
> Files=17, Tests=631, 3 wallclock secs ( 0.27 usr + 0.09 sys = 0.36 CPU)
> Result: PASS
> testPVCopy.t ......... ok
> testPVRecord.t ....... ok
> testExampleRecord.t .. ok
> testLocalProvider.t .. ok
> testPVAServer.t ...... ok
> Files=5, Tests=81, 1 wallclock secs ( 0.06 usr + 0.03 sys = 0.09 CPU)
> Result: PASS
> testmon.t .. ok
> Files=1, Tests=79, 0 wallclock secs ( 0.05 usr + 0.01 sys = 0.06 CPU)
> Result: PASS
> testweak.t .. ok
> testtest.t .. ok
> testpvif.t .. 1/71 Command stopPVAServer not found.
> testpvif.t .. ok
> testpdb.t ... ok
> Files=4, Tests=247, 2 wallclock secs ( 0.08 usr + 0.05 sys = 0.12 CPU)
> Result: PASS
> This is for windows-x64-static
> H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64-static
> Snippets.t .. ok
> Files=1, Tests=29, 2 wallclock secs ( 0.03 usr + 0.00 sys = 0.03 CPU)
> Result: PASS
> epicsErrlogTest.t .......... 25/32 log client: connected to log server at "127.0.0.1:61307"
> Test Summary Report
> epicsMathTest.t (Wstat: 0 Tests: 35 Failed: 0)
> TODO passed: 8-9, 11-12, 22-23
> Files=40, Tests=4016, 204 wallclock secs ( 0.56 usr + 0.16 sys = 0.72 CPU)
> Result: PASS
> {"x":bbbb}
> {"z":{"good":6}
> dbServerTest.t ............. dbRegisterServer: 'one' registered twice?
> dbServerTest.t ............. 1/24 dbRegisterServer: Bad server name 'bad name'
> Files=20, Tests=2856, 82 wallclock secs ( 0.51 usr + 0.08 sys = 0.59 CPU)
> Result: PASS
> msi.t .. ok
> Files=1, Tests=9, 0 wallclock secs ( 0.03 usr + 0.02 sys = 0.05 CPU)
> Result: PASS
> linkInitTest.t .......... 8/77 dbRegisterServer: 'rsrv' registered twice?
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> 0x10
> regressTest.t ........... 6/31 dbRegisterServer: 'rsrv' registered twice?
> simmTest.t .............. Failed 3/1176 subtests
> Test Summary Report
> Result: FAIL
> tsTest.t .... ok
> dbndTest.t .. ok
> arrTest.t ... ok
> syncTest.t .. ok
> Files=4, Tests=1612, 3 wallclock secs ( 0.19 usr + 0.00 sys = 0.19 CPU)
> Result: PASS
> Base.t ........ ok
> Breaktable.t .. ok
> DBD.t ......... ok
> Device.t ...... ok
> Driver.t ...... ok
> Function.t .... ok
> Menu.t ........ ok
> Recfield.t .... ok
> Recordtype.t .. ok
> Registrar.t ... ok
> Variable.t .... ok
> Files=11, Tests=287, 1 wallclock secs ( 0.00 usr + 0.01 sys = 0.01 CPU)
> Result: PASS
> Files=33, Tests=2248, 294 wallclock secs ( 0.64 usr + 0.11 sys = 0.75 CPU)
> Result: PASS
> Files=10, Tests=6192, 28 wallclock secs ( 0.48 usr + 0.05 sys = 0.53 CPU)
> Result: PASS
> Files=17, Tests=631, 3 wallclock secs ( 0.14 usr + 0.08 sys = 0.22 CPU)
> Result: PASS
> Files=5, Tests=81, 2 wallclock secs ( 0.03 usr + 0.01 sys = 0.05 CPU)
> Result: PASS
> testmon.t .. ok
> Result: PASS
> testweak.t .. ok
> testtest.t .. ok
> testpvif.t .. ok
> testpdb.t ... ok
> Files=4, Tests=247, 4 wallclock secs ( 0.08 usr + 0.02 sys = 0.09 CPU)
> Result: PASS
> Mark
> *From:*Mark Rivers
> *Sent:* Friday, December 29, 2017 8:06 AM
> *To:* Michael Davidsaver; 'Andrew Johnson'; '[email protected]'
> *Subject:* Re: Problem building example application on windows-x64
> I have tested the fixes.
> I did the following in module/pvData and modules/pvAccess
> git checkout master
> git pull
> Rebuilt base for windows-x64 and windows-x64-static.
> Rebuilt example application for both ARCHs.
> It appears to fix both problems:
> - windows-x64 no longer hangs with WINSOCK errors when exiting.
> - windows-x64-static no longer crashes on startup.
> Thanks,
> Mark
> *From:*Michael Davidsaver <[email protected] <mailto:[email protected]>>
> *Sent:* Thursday, December 28, 2017 12:23 PM
> *To:* Mark Rivers; 'Andrew Johnson'; '[email protected]'
> I have committed possible fixes for the first two issues.
> On 12/28/2017 09:37 AM, Michael Davidsaver wrote:
>> So much for that. I manged to miss this issue. Time to open some tickets I think.
>> So far I count four distinct symptoms, and the test failures.
>> What I see so far:
>> 1. Global ctor ordering issues needs to be opened against pvDataCPP and pvAccessCPP
>> (any probably others).
> https://github.com/epics-base/pvDataCPP/issues/49
> w/ candidate fix
>> 2. The osiSockAttach() issue against pvAccessCPP.
> https://github.com/epics-base/pvAccessCPP/issues/81
> w/ candidate fix
>> 3. The Com.res failure against Base (on launchpad)
> https://bugs.launchpad.net/bugs/1740408
>> 4. The timestamp issue w/ genVersionHeader.pl against Base
> tbd.
signature.asc
Description: OpenPGP digital signature
- RE: Problem building example application on windows-x64 Mark Rivers
- Problem building example application on windows-x64 Mark Rivers
- Re: Problem building example application on windows-x64 Andrew Johnson
- Re: Problem building example application on windows-x64 Michael Davidsaver
- Re: Problem building example application on windows-x64 Mark Rivers
<2017>
<2017>
